General Setting Up A Plane
Bruce Maura
I am using a spectrum DX8. And aAR9350 receiver problems ailerons are like they are Y Ed right elevator doesn’t see the gyro and I can’t figure out how to turn ignition on and Or off?? And a switch for gyro either?
Beyond the standard ailerons, elevator, rudder and throttle but different brand/models of receivers still may use different default channel setups... the rest of it is non-standard and requires you to follow the instructions for whichever parts you've chosen ( in this case the AR9350 ).... So I'll link you to their product page which has links to a quickstart guide ( PDF and video ), firmware updates... and the manual...
AR9350 9 Channel AS3X RX with integrated telemetry (SPMAR9350): Spektrum - The Leader in Spread Spectrum Technology
