I am at the stage of setting up my Align 800E Trekker with a 3GX Gyro unit that came with the kit using Tony's 5 instruction videos. The 3 servos are all digital Align units (not rudder at this stage). What is happening is that there is a slight jittery sound coming from the pitch servo when you put your ear up close to it, but otherwise it seems to be functioning OK. We were getting small involuntary jumps every few seconds from all three servos but that seems to have stopped since I made pitch and throttle adjustments in the transmitter in accordance with Tony's suggestions which may have just been a fluke. What happened earlier in the build, before E-ring was enabled in the transmitter (which is supposed to protect the servos from overloading), the pitch servo got red hot (unbeknown to me initially) and I actually burnt my finger on it. Could I have caused a long term problem within that servo and what should I do?
Thanks in advance.
Ian.
Thanks in advance.
Ian.
