Vertical tail fin vibrating means trouble to be honest heehee.
Balance your tail blades and check all the way through for anything warped slightly. Tail output shaft may be?
Scale fuselages do tend to have a tendency of shaking a LOT! They cannot take high head speeds. If you were running a head speed on your stock (pod and boom) heli.. You cannot run that same head speed on that heli with a fuselage. The heli's frame is not designed for the fuselage but the fuselage is designed for the heli. So.. With so many different parts ok the fuselage, and gaps and all that structural stuff, the fuselage will tend to vibrate and shake to a point of fatigue and cracking.
If you are a 100 percent sure that you didn't have these shakes before putting the fuse on, and now you have them then lower down your headspeed through ye throttle curve and the of course you'll have to play around with the pitch curve to get it right..
If you have a doubt, check everything again. Definitely balance your tail blades. They are a very common point of failure sometimes. Even in 450 size.
Anywaz. If all that's done then head speed.
