Can you tell us what you mean by "four stroke"? Do you mean you think it's missing?
If the idle is too low, you can try to adjust the idle screw (should be on the front of the carb) an hour and try it again. Remember, open the throttle a little so you are not pushing against the bore.
You can also try leaning out the bottom end a little bit. before I explain, this can throw off your tune. The low end needle is in the middle of your linkage on the carb. You will see a little flat blade screw. CW leans, CCW richen's it up.
Make sure your clutches are not dragging. If you are running a spring on your clutches, make sure it's not broke, or "they" are not broke if you have a spring per clutch.
If none of this works, you may try putting on a heavy weight flywheel. This will make it idle a lot better.
