buel williams
Hi all hope everyone had a safe 4th, just a question about a heli's rudder if you lost your rudder can it be saved without major damage. heli that is.
wow Geena that's great news to my ears can you give me any hint's on how you did it?Yes, it`s possible to save the helicopter if you lose rudder. I have done it a few times due to servo failure twice, and a broken bell crank one time.
ok I got it but every little thing helps so thank you very much.Well.... there is no easy way to explain it. But you do have to hit throttle hold, so that the helicopter will stop yawing. From there, it`s a matter of 10% skill, and 90% luck. Every time it!s happened to me, it`s been with a 600-700 size helicopter. It`s going to be very difficult with a 450 though.
oh yea the trusty simm thanks again.What I try to do, is keep the disc as flat and level as I can. It`s like doing a stationary piro, but really fast. Then I get the helicopter down to about 2 feet from the ground before I hit throttle hold. Throttle hold will usually stop the helicopter from yawing, and you just let it settle down and land. You need to be able to land in any orientation though, because you never know where the tail is going to be when it stops yawing. Also. if you give too much positive collective when you let it settle, there is a good chance the helicopter will start yawing again when you try to land.
I suggest setting up in flight failures on the simulator and practice it.
Next best thing to peanut buttertrusty simm
