I want to know that how do I reverse the shaft of the brushless motor as the Motor's base is rotating and I have to put the motor outside the fuselage because of the rising the temperature inside the fuselage by the motor,ESC.
When I placed my motor inside and then try to start with the propeller fixed suddenly the motor borked the mount and jumped out of the fuselage breaking all the connections
The motor which I had buy has 4 holes in front and 3 holes at the base i was given with mounting plate for the 4 holes but not for the 3 holes
I could have made it myself but the problem is that the base of the motor also rotates When the motor is turned on
So tony sir I would like to ask you to make a video on how to reverse the shaft of a brushless motor as the videos available on YouTube are not too good
Thank you
And I'm using Odin 2836 KV1000
Thank you
