Hi I'm fairly new to the helicopter scene. Had cars and airplanes and have a dauphin 250 coaxial which got boring after a while. Bought a e-razor 450 which is a completely different animal... Had a small crash (just the blades) but I believe the motor moved a tiny bit after 3 more hovering flights the main gear stripped out and had to replace it. To do so I had to take the frame apart ... after replacing and putting it all together I tried to take off and the heli will take off but as soon I get speed the heli will spin either right or left. I checked the servo (put another one in...).
When I checked the tail rotor and try to adjust to put it into the middle it always moves either to the far right or the far left. Even with the trim 3 small clicks to the right the tail will move from the very left to the very right and vice versa 3 clicks to the left the tail will move to the very left. Is my Giro broken or do I need to reset the Dynam remote to factory setting (which I have no idea how to do...) Can somebody please help? Frank (newbie)
