  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Other Receiver Inputs Rc Kyoshu Optima
Discussion in 'Transmitters & Receivers' started by Kevin Mcgrath, Nov 29, 2017.
< Spektrum Ix12 | Orange Rx >
  1. Kevin Mcgrath
    Kevin Mcgrath New Member
    Blog Posts:
    0
    Nov 29, 2017
    10
    0
    1
    Gender:
    Male
    Bridgwater UK
    Hello
    This is my first build which i am doing for my son as a birthday present, i am a total novice and i have run into problems, could any one please help or point me in the right direction please.
    I have recently purchased the Kyoshu Optima RC Car and thought i was getting on OK until the point where i had to install the receiver -and stuff that plugs in to it.
    Question 1
    Reading the manual of this i think (and only think) that the bottom(channel 1 is the steering servo)-below
    Am i correct in thinking this? and if so which way do i plug it in (which colour cable goes notch side on the reciever?)
    Question 2
    My next question is the 2nd slot up ch2,
    Again through looking at the manual this should accommodate the speed controller which i believe to be this
    If i am correct, which way round do i plug it in(notch side) and do i need to worry about the settings with the jumpers?
    Question 3
    My final question for now would be regarding the blue and yellow lead running from the speed controller, where do these go on this motor?
    Thanks for looking and hoping someone can help.
  2. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,505
    1,391
    113
    Below is the manual for that Tx/Rx. It will show diagrams on how to wire things up. But you are correct, Channel 1 is steering and channel 2 is for the ESC, and you were correct on the ESC. The light colored wire (yellow or white) will go to the label side (left if your looking at the top of the Rx reading the text) and the dark colored wire will go to the right or on the outside of the Rx.
    Since this is a brushed motor, just plug it in and if the car runs backwards, just reverse the wires.
    As for the jumpers, Leave them as is. It is set to NiMh which is the battery type pictured in your pictures and you definitely want forward, brake and reverse for just bashing around.
    Hope this helps.
    Need to find another manual, that one is 105Mb which is WAY too large for what it contains. I will upload a file when I find one.
  3. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,505
    1,391
    113
    Here you to, much smaller than the last one lmao.
  4. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,505
    1,391
    113
  5. Kevin Mcgrath
    Blog Posts:
    0
    Nov 29, 2017
    10
    0
    1
    Gender:
    Male
    Bridgwater UK
    Thanks for your time and help, so now i know that the ESC goes to channel 2 with the white wire going inwards to the label side.
    Which direction do a face the steering servo in channel 1?, the cable has Brown,Red and Orange.
    The motor has four terminals, 2 with a resistor in between and two without, do i plug resistor side or opposite? or maybe one on each?
    I seriously have no idea.
    And thank you very much for taking the time to find a Manual, i am sure my internet will cope with the size.
  6. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,505
    1,391
    113
    Actually, those are just bullet connectors, not resistors. They are there so that you can remove the motor without wearing out the crimp terminals that go on the motor. But the bullet wires go to the motor. Again, if the motor spins the wrong way (car goes into reverse when trying to go forward), then just swap those two wires around on the motor.
    And the orange wire will go to the inside towards the label. The way those wires are labled is red=power, brown or black = ground and orange or white = signal.
    And no worries about not knowing. My favorite saying is "No one know what they don't know until they know it". We all started somewhere.
  7. Kevin Mcgrath
    Blog Posts:
    0
    Nov 29, 2017
    10
    0
    1
    Gender:
    Male
    Bridgwater UK
    Thanks
    Sorry to continue to be thick, do i put the wires resistor looking side or the other
  8. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,505
    1,391
    113
  9. Kevin Mcgrath
    Blog Posts:
    0
    Nov 29, 2017
    10
    0
    1
    Gender:
    Male
    Bridgwater UK
  10. Kevin Mcgrath
    Blog Posts:
    0
    Nov 29, 2017
    10
    0
    1
    Gender:
    Male
    Bridgwater UK
  11. Kevin Mcgrath
    Blog Posts:
    0
    Nov 29, 2017
    10
    0
    1
    Gender:
    Male
    Bridgwater UK
    hope that clarifies my question
  12. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,505
    1,391
    113
    Absolutely it does, sorry about that. The side doesn't matter, you can put the plugs on either side. Just what ever is most convenient when the motor is mounted.
  13. Kevin Mcgrath
    Blog Posts:
    0
    Nov 29, 2017
    10
    0
    1
    Gender:
    Male
    Bridgwater UK
    Brilliant, thanks for that, so sorry to not make a lot of sense, i am gonna continue the build on Saturday which i would not be able to do without your guidance, thank you so much.
  14. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,505
    1,391
    113
    It's my pleasure Kevin.
Share This Page
