llommel
I just built an RC ice sled to run on the frozen lakes & snow. Still working out some kinks. One of which is the throttle control.
I am using an Exceed RC Rocket motor, # 86ma12 2220, 1050Kv with a 10x4.7 prop. I'm using the Dynam TX & RX that came with the E razor 450. (switched the 450 over to the DX6i). Using Skyli-po 2200mAh, 11.1v 40C battery.
The problem is when I run the throttle full stick, then slow down, it will not speed up again unless I run the throttle all the way to "0" B4 I open the throttle all the way again. Just wondering if anyone knows what might be the problem.
