  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
General Rc field Battery
Discussion in 'Airplanes' started by Curtis A White, Mar 20, 2017.
< Scratch Build Delta Wing with Naze32 troubles | Appentice s15 >
  1. Curtis A White
    Curtis A White New Member
    Blog Posts:
    0
    Mar 20, 2017
    5
    0
    1
    Gender:
    Male
    Grand Junction Colorado
    Hello, Excuse my lack of experience on this I am fairly new. My question is, I have purchased a Graupner battery charger and I'm trying to charge my pb and its giving me a choice of efferent charges,( per cell I'm thinking), and it ranges from 1.81 volt to 2.45 volts, can anyone help me on this? Thank you, Curtis.
  2. holtneil
    holtneil Active Member
    Blog Posts:
    0
    Feb 15, 2014
    818
    26
    28
    United Kingdom
    Hi mate pb is lead acid battery like you have in your car , so should not be asking cells just voltage which is 12 volt
    on some they do count cells which should be 6 cells at 2 volts per cell which gives you the 12 volt
  3. Curtis A White
    Blog Posts:
    0
    Mar 20, 2017
    5
    0
    1
    Gender:
    Male
    Thank you for your reply!
  4. holtneil
    Blog Posts:
    0
    Feb 15, 2014
    818
    26
    28
    United Kingdom
    Hi Curtis I added to the last message go for 6 cells 2 volts per cell this will give you 12 volt
  5. Curtis A White
    Blog Posts:
    0
    Mar 20, 2017
    5
    0
    1
    Gender:
    Male
    Thankyou very much!
  6. holtneil
    Blog Posts:
    0
    Feb 15, 2014
    818
    26
    28
    United Kingdom
    Dont forget the lead acid battery will gas so charge out side if you can
Share This Page
