Graham Jones
I could really do with a little help installing the Spectrum AR6210rx into my Razor 400, I am using the Dx6i tx. I followed Tony's brilliant utube video setting up a razor450 but all has not gone well. I have tried various connections, the rudder seems to function correctly. I have connected the forward servo which I think should be the elevator into the elevator socket and the two other servos into the Aileron and Aux sockets. This does not work and leads to diagonal movements of the swash plate when useing the left stick up and down. The only way I have managed to get the pitch working correctly is to plug the forward servo into the aux socket. This then works the swash plate level up and down, down giving lift. However it leaves the cyclic working incorrectly, when in the 12/6 position I get left and right roll. In 9/3 movement I get forward and backward movement. I have tried several mixes in the swash settings +/- settings but nothing seems to resolve this, I would be glad of any help you can offer please? Thanks Graham Jones.
