General Raven 30e
Zuunnii
I need some help, l have raven 30E 3d plane . And I bought (grand turbo 1100kv motor and 40A esc with 3cell 2200mah battery )
Is this good setup for this plane . And can anyone tell me about servos for this plane
motor esc and battery should be fine provided the battery's C rating is high enough. As for the servos, I can't find any specs on that plane as to what type of servo it takes. You will need to measure the holes and get a servo that fits.
Zuunnii
Ok . I m beginner . And thus is my first 3d plane . Can u recommend me the full setup for this plane .
Unfortunately we can't. Every plane and Tx setup is going to be different. The video below may be able to help you out on setting it up. It shows how to set your control throws and such.
