600 Raptor X50 converted to electric **HELP**
scale_operator
So I have a raptor x50 that I converted to electric and I kept the clutch. I'm having problems with over heating. Data shows 28.4 amps max draw @ 1327 rpms, 177.1°. After the flight motor and esc are HOT. On top of that when I give her more throttle the tail wags violently from side to side. Any help would be appreciated. I've been doing research and seen people with similar setups that have no problems. What am I doing wrong. Here's what I'm running:
CC 120HV with 20 amp Ext bec
Scorpion 4025-550 kv
Gearing is stock x50, 10t pinion, 85t main
RCA 5-blade with heli-scale 580 semi-symmetrical blades
Ikon flybarless for stabilization
Thanks for the help.
