callsign4223
I have been reading around trying to figure out the best way to charge all 6 of my mcpx batteries at once. What I don't get is that some people are saying that all the batteries have to be discharged to the same level for a parallel lead to work.
What happens if the batteries are at different charge levels?
Also, what if some of the batteries are 200 mah and some are 300 mah?
I did read that you could use a balance charger lead to get around the different charge levels, but is it really necessary and how would you construct one?
It was also said that if you use a balance charger lead and you have a bad battery none of them will charge, is this correct?
I know these are a lot of questions, but it seems the more I try to research this the more confused I end up making myself. Whatever type of leads I do go with I am planning on attaching it to a Thunder AC6 in case it makes a difference. Thanks for the help guys.
