Aregorn1
I am getting ready to get the electronics for a foamie, it is the Extra 300 from RCPowers and I want to make a change to the plans a little. Tell me what you think. I would like to put "wiglets?" on the ends of the wings, make it a tiny bit tail heavy, and set it up to fly SLLOOWW. I guess you would say "Close" to a 3D but not quite there, if that makes any sense? Here are the questions. Would the "wiglets?" work on stability? How far should the Ailerons, Elevator, and Rudder move? Lastly what should I put in it for Power, (Motor, Esc, Batt, and Prop)
THIS IS THE INFO ON THE PRE-CUT VERSION
I don't know, would the default make it a slow-flyer?
What do you think?
Any help would be great.
Thanks
Michael
Here is a Pic of the default build.
By "wiglets?" i mean those vertical plates on the ends of the wings and tail.
- 2208-17 Brushless Motor & 18A ESC Combo
- GWS 9x5 Propeller
- 4 x ParkFlyer Servos
- GraysonHobby 800mAh 11.1V 15C/20C
- RCPowers Extra 300 Laser Cut Depon Kit
- RCPowers Extra 300 Airplane accessory bag. (Carbon, pushrods, control horn, and motor mount)
Type: Parkflyer
Motor Class: 400
Length: 36 â€
Wing Span: 35½â€
Total Flying Weight: 12 oz
Motor Class: 400
Length: 36 â€
Wing Span: 35½â€
What do you think?
Thanks
Michael
