That is done with the URL part of the picture input tab. You will have to upload the pictures to here on the forum, or on photobucket or something, then put the URL in that box. I will see about doing a quick video on this. It's kinda hard to explain but pretty easy once you try it a couple times.
The easiest way to do it is you just won't use the image button above the editor. Instead you will put [.img]yourURLhere[/img] but without the period in the first box. By doing that, you will embed the picture in it's original size. However, I do ask that a MAX size of 800x600 is used. Or, noting over 800pix wide.
