FBL Gyro please help! 3gx gyro governor stuck on.
Mike Soby
I have a 550 dfc with 3gx and i cannot get the governor to turn off. I seen the rchelp.com video explaining the light but never said how he was turning it on and off.
I don't have much experience with the 8j, however, to turn the governor off, I think you need to take channel 5 (might be 7, one is gyro, one is governor. On spektrum with sats only, 5 is gov) and play with the value until the gov turns red.
However, no matter what color the governor is, unless you have a sensor plugged into it, the governor will do nothing. Mainly only works on nitros.
Mike Soby
I will have to try that thank you. I know my esc has a governor in it but i turned it off in the esc. Not sure why my headspeed will not go up.
Have you calibrated your throttle on the tx to the esc? And what is your throttle curve?
Mike Soby
Yes, and my throttle curves are normal: 85 85 80 85 85 and idle up is 95 95 90 95 95. When i hover headspped seems very low. And if i hit idle up it doesnt increase at all.
