Misc Play in motor
WyDiablo
Should there be any up and down play on a motor shaft or should the bell be snug to the borrom? Mine at about a 1/64+ play. I got my CF props yesterday and was going to try then out and found out that they are not marked right or left hand rotation. So I took a guess and put the props with the outward leading edge on the left side of the prop to be a right hand turn. And the leading edge of the prop on the right side to be the left hand turn props.
WyDiablo
Not any kind of lettering or numbering at all. I did match each propr with the one that I was replacing and each one looked like the right prop. I did fly pretty nice after installing the Cf props and man are they stiff.
breeze400
Spagetti Pilot
If it flys, it should be right! LOL. I had lots to do today so I'm crossing my fingers that it's some what dry tomorrow!
There should be a little play in the motor. If there is not, then it's binding and you will lose power and over heat your motor. Looks like you have it flying quite well!
