Probably the most asked question. I have tried to set up the pitch. I have followed all the instructions from Tony's and others videos but I have run into a problem. I have set servo arms to 90 degrees when in IU mode and 50% throttle but the pitch gauge is off the scale over 35% at mid stick and the swash seems to be very high in fact servos are beginning to stall at full thrttle. All the push rods are measured correct so I am obviously doing something silly or missing the obvious. Any help would be most appreciated. Cheers
