coolgabsi
Super Mod & DEAL KING!
So ...
I have been hearing a bit too much about 3.0 is this 3.0 is that.. BLAH blah BLAH blah BLAH!! lol So i decided to do the upgrade to 3.0
Ok. got the thing updated successfully.. did the DIR setup.. Did the Gove setup by giving it the throttle high and low positions.. ok .. looked ok..
THEN.. I connected the software and lowered the roll rates on ele and aile.. as I like it lower than stock..
OK.. Went out today to fly.. Spool up. Ok.. idle up 1 .. OK. Idle up 2 SHAKE!!!! Elevator wobble.. Out of this world.. swithc down to ID1 and bird is stable as a rock..
LOWER THE GAINS you would say.. sure.. I was at 65~70 at the pots on my 3GX and so I lowered it down to 50.. still a bit shaky.. LOWERED it even more to between 30~40 .. much less noticeably shake.. but still see some in FFF.. WHAT!! I had been flying those gains on 2.1 and all that changed was the software update.
OK.. so.. did some inverted funnel .. and all of a sudden and I notice at the farthest point ofcourse (the bird just started to fall) i left the sticks.. and let it settle slowly cause I knew I wsa going inverted tail in.. somehow I was nose in inverted now.. and then I did some pith pumps to see if the tail would give.. NOPE.. but the stupid thing gave in a full 180 degrees randomly again. I was SO PO'ed.. I hated it.. Almost ost the heli on it.
NOTHING has changed. Did the gov setup like I was supposed to.. Tail delay is set to "red" for 450 size helis.. and everything else is just the way it was.
This 3GX is in a pile of doodoo for me now.. till it can fly right again.. if it does..
Help me troubleshoot this guys.
