As you may have watched in the article that I put up earlier, Rc-Help now has it's very own Align T-Rex 150 DFC thanks to NEXRC HOBBY! The helicopter that i have is the first version with the plastic arms and swash, but I assure you, it will not stay that way for long. If you have not watched the video, you can see it by clicking the link below.
Rc-Help - Align 150DFC From NexRc.com
At this time, I have plans on doing a blade comparison video between the black/white Align blades, Orange/white Align blades and the 3D and weighted MicroHeli blades of different colors. I'm also going to do, at the same time, the 42mm and 47mm tail blades.
The only issue that I know for a fact that is an issue is the reverse flight tail stability. I will be trying to hone my skills in my reverse flight so that I can properly test this issue. Then we will see if the stock Align, 42mm microheli or 47mm tail blades will solve the issue.
If you have any other videos that you would like to see, please post them in this thread, or in the article I posted above.
