concodd
Hi people, the replacement 3GX arrived today and was installed. All settings were done again, and guess what! The tail servo is still not working. When I plugged it in there was a slight sound from the servo but that was it. I thought the lead might not be in properly so checked that, still nothing so then I replaced the the extended servo cable just in case there was a fault with the first cable. Again still nothing. So I again connected up the servo tester and the servo worked perfect in manual and auto mode. There is a signal from the TX to the 3GX because when I did my settings for the servo speed and analog or digital type servo the corosponding lights changed when requested by the TX. Any other thoughts on this continuing problem.
