concodd
I think I have solved the problem, but not sure how to fix it. I connected everything back up and went through all my alignments again right upto the rudder part. But again no movement in the tail servo. So I disconnected it. This time I left the connector cable (extended cable connector) in the 3GX and plugged the other end into the servo tester and then connected the servo to that. The servo worked perfectly. So the power is there and the cables are connected correctly but the message is not getting from the TX to that servo. Is there something that can be turned off in the TX that maybe not switched on that I do not know about??
