Keith
Was out shopping yesterday and found a place with stacks of foam...Been looking for a while... Quite big, about 2' x 4'... Got a couple of sheets and thought I would give the scratch build a go...
Looking on Youtube and came across foam cutters... I thought I can make one of them and cut some nice wings.. Found a voltages regulator off an old ceiling fan and went through all my transformers I had lying around... The best I could find was a 12v @ 1Amp... Might be enough..
So joined it all up and connected the multi-tester... Got 3 settings on the controller... Low = .02v... Med = 2v... High = 10.4v... Think I might need a bit more power... Then I remembered my car battery charger... Connected it up, got nothing on first two settings but high gave 10.4 again but it would be at 4.5 Amps... That should heat the wire... Then I remembered it had a booster/fast charge setting... Flicked the switch and got 12.5v...You beauty...
Have ordered some nichrome wire so when that arrives I can set it up... Couldn't wait to see if it works so found the thinest wire I had, bared the ends and attached the crock clips... Flicked the switch on the wall and before I could look down the wire burst into flames... The coating was well alight... I was blowing and hitting it until I put it out.. That was after I killed the power.... So it wasn't too bad except for one thing... I like to work on a white towel so when I drop small screws etc they dnn't roll everywhere...
Just got to hide the towel from the trouble and strife and I should be OK... Think I'll wait for the correct wire before I try again.....
