mooserider
Hi! This is my first helicopter build and I have a few newbie questions. I watched the youtube series on going through the 3GX configuration, which helped a lot! But a few things don't seem to be set up right on the heli still and I had another question about the rudder push rod.
This is for a Trex 450 pro dfc, spektrum dx7 (airplane version), using the receiver as a receiver with one satellite. I'm using a receiver battery pack w/o the lipo so the motor doesn't work during setup.
* Main rotor blades - When the throttle is completely off (all the way down) in normal flight mode, are the rotor blades supposed to be pointing down (neg pitch)? I kind of assumed that they should be level until 50% throttle, and after that they would increase (start pointing up). In other words, no downward pitch unless you're using idle-up. Not sure if this is normal or if I am missing something in setup.
* Anti-torque rotor? When I increase the throttle (without the motor battery plugged in), the tail rotor pitch doesnt' change at all. Another assumption here, but I thought that it would change in pitch along with the throttle increase to compensate for the torque. Not to be confused with when the tail is moved left and right (yaw), and the gyro auto-compensates and changes the pitch. Will this only work if the motor is spooling up or is this something I'm just confused about?
* Tail rotor throw range - even after going through the tail rotor 3GX setup, the throw on the tail servo is still going to its maxes, causing binding in the rod. Not sure what I'm missing. The step in setup to do this has you move the left stick left until the blades are at their limit, wait for the status to start flashing red, then you do the right too. Then you press the button on the 3gx and do the delay. One weird thing is that you barely need to move the rudder stick left/right at all, as just a little stick movement will cause the rudder blade pitch to keep changing until it reaches its limit.
* Tail rotor push rod - This little thin metal wire is way too flexible. There are only two of those push rod guides, and they also move around. I'd like more like 4 of those things and lock them all down somehow, but they only gave me 2. I can't imagine actually flying it like that. Any suggestions?
I can't seem to find a way to export all of the settings from the 3gx. You can 'save', but the txt file it creates doesn't have all the same numbers I see in the UI. Below is a copy of the settings from the saved file though. I have some screen shots of the other stuff, so I'll try attaching it.
Thanks for any help you can provide! It's taken quite a time to get this far, but I'm almost there.
Settings file from 3gx:
0;
1;
0;
50;
0;
0;
0;
20;
20;
20;
1;
0;
20;
70;
70;
0;
80;
70;
70;
70;
50;
60;
50;
20;
Added attachments with settings parameters.
View attachment SettingDisplay.txt
0;
1;
0;
50;
0;
0;
0;
20;
20;
20;
1;
0;
20;
70;
70;
0;
80;
70;
70;
70;
50;
60;
50;
20;
