  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Projects New Project
Discussion in 'Airplanes' started by grumpy1, Dec 13, 2018.
< Sub Micro Servo | My First Plane >
  1. grumpy1
    grumpy1 I Support Rc-Help! Rc-Help Supporter
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    pipe welder. .pipe fitter. .asme code pipe shop fo
    hull,ga
    Well so far new project is looking good ..a REAL scratch build...cessna Agwagon...60.5 w/s .....what a task cutting an shaping wing ribs..no problem, I got more time than money lol, but anyway got all fuse formers cut out ....firewall. .just about to have wing complete....here's a question gonna have flaps ..my question is plain flap vs split flap.. From what I've read split is the most "draggest" really slows down without as much loss of lift an can have much steeper descent..an that on take off with split flap not as much deflection to get same lift charteristics with less drag as plan flap ..know it's not to scale ..just like the looks of split flaps..:argue: I
  2. Tony
    Feb 21, 2011
    36,763
    1,423
    113
    I have always just used standard flaps. Way easier to put into a plane.
  3. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    That is the easy way out, but hardly ever see split flaps, Well at our field anyway...is it true that split flaps generate more drag on decent opposed to plain flaps an it take less flap deflection an less generated drag on take off opposed to plain flaps
  4. Tony
    Feb 21, 2011
    36,763
    1,423
    113
    Quite honestly on models this small, you won't notice much difference between any of the flap designs.
  5. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    Anybody had any experience with the the electric smoke system from MrRcSound smoke system..thinking about installing that on this Agwagon with under wing spray bar
  6. Tony
    Feb 21, 2011
    36,763
    1,423
    113
    Nope, never played with those.
  7. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    Well making some progress on new project. .
  8. Tony
    Feb 21, 2011
    36,763
    1,423
    113
    Nieeeeeece!!!
  9. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    Anybody know if a 4-40 left land swivel ia available, even no returns even from Google, what I'm trying to do is on that wing it has a wing strut from top of wing to fuse. Want to make turn buckle type strut with swivel at wing attach point an 4-40 clevis at fuse attach point..that way no loose parts to lose when assembling at field ...just spread clevis an insert in tab..no loose parts to drop
  10. Tony
    Feb 21, 2011
    36,763
    1,423
    113
    Not that I'm aware of. I have never seen one in the years I have been in the hobby. I just did a search and the only thing I found was 4-40 left handed bolts and threaded rod. Which does no good without the clevis.
  11. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    Looks like I will have to make an insert...a heli coil...the barrel on dubro 4-40 ball swivel has .2295 od drill that out to #36 drill an tap for 6-32. Next cut 1/2. CR rod 1" long. Chuck up in lathe bore #36 hole an tap 6-32 ...install 6-32 x 1 screw. Turn part around in lathe screw head inside Chuck now bore #43 hole to a depth of .500 an tap to 4-40 left hand. Only reason for 1/2 rod is to hold screw on ctr to chuck up on lathe. Screw into ball swivel put some #620 loctite bearing retaining compound on 6-32 threads, so now cut head off screw with cut off wheel..got a 4-40 left hand ball swivel ....think it will work
  12. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    There's 2 ways that could be done make a 4-40 right/ 4-40 left all thread stud then have 4- 40 left hand male swivel. This way isn't as much work. Any thoughts:argue:
  13. Tony
    Feb 21, 2011
    36,763
    1,423
    113
    I didn't know you had a lathe or the bits to accurately do 6/32" threads. What you are saying is making sense to me and as long as it works I think it's a perfect solution. If you do what I'm picturing that is lol.
  14. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    I got a pretty nice well equipped home machine shop..13 x 40 gear head lathe, 9 x 42 milling machine, 2 sheet metal brakes both are pan brakes with removable fingers, syncrowave 250 Miller welding machine, 200 Miller matic wire welder , iron worker,drill press, 10" rotary table, 5c spin index, all kinds of tooling for mill an lathe boring bars, end mills.. etc
  15. Admiral
    Admiral Well-Known Member
    Mar 2, 2014
    2,048
    125
    73
    Gender:
    Male
    Occupation:
    Information Technology (Retired)
    Brisbane, Australia
    Nice workshop.
  16. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    My past hobby it almost a necessity, but never thought I would need some of the same equipment in the rc world ...who would have thought I sure wouldn't have
  17. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    Got some more tooling for shop today, mail lady brought a 4-40 left hand tap an die today to make left hand swivel for wing strut. Gonna make the 4 tube inserts tomorrow or Monday , have some .250 hex 6061 aluminum. What would suggest on holding stud into swivel..jam nut..put some CA on threads ...loctire red ? I've got some .1875 x .014 wall aluminum to use as strut itself...that an some brackets will probably be some of the test parts for anodizing project.
  18. Tony
    Feb 21, 2011
    36,763
    1,423
    113
    I would just make some jam nuts with the aluminum rod you are going to use. Finding left handed 4-40 nuts is going to be a chore. Making your rod a tad longer than you need and just cutting off a nut from it is by far the easiest way. CA will come loose, surely not red thread locker unless you never want it to move again.
  19. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    I'm not talking about on left hand threads had already decided to make jam nuts for strut out of that hex anyway both right an left jam nuts for strut . I'm talking where that right/ left rod screws into swivel left hand stud is left to screw into strut
  20. Tony
    Feb 21, 2011
    36,763
    1,423
    113
    Oh, the plastic end? If so, a slight knurl on the threads and screwing it on quickly should hold that just fine. If you are already holding the shaft into the turnbuckle and the plastic end is held with something else, it's not going to spin out of there. And if there is something that is strong enough to pull the threads out, there is no option that can stop that lol.
Share This Page
