Westy
LEGEND
hey all .... wow I am such a SCHMUCK!
SOOOOOOOOO LUCKY!!!!!!!!
I am doing some renovating and removing some walls etc and making some changes. So, I was grinding some nails off on the top plate and saw some embers.....
Turned off the grinder and .... WOOOFFF the Rok Wool (basically insulation in the roof made of small paper ground up and compacted and pumped into your roof).
Embers were coming down on me..... I was like...... NOOOOooooooooooooooooo......
So I in a mad panic ..... and brute strength (Full of adrenaline) ripped an entire sheet of ceiling sheet down and most of the smouldering stuff came down with it. The embers were flaming up on the floor and the hot embers were rising and catching the roof again !!!!!
NO FIRE EXTINGUISHER EITHER!!!!
SO I sprinted to the Kitchen ... and Ripped 3 pots out of the cupboard and turned all the taps on full bore.... Filled one pot and put the next in place ... and sprinted to the fire scene. First one went on the ground fire .... Sprinted beack ... Switched pots again ..... and hit the roof hard out ... back and forth and back and forth .... about 10 times.
I was lucky enough to get it under control and just to be sure I poured water into the surrounding cavities and pulled all the rokwool out of the area (about 2 square meters).
Man I am still shaking with the adrenaline rush. i am off to get an extinguisher and fire blanket right now. I did not even think about the paper insulation catching alight ... and it happened sooooo fast!
Lucky I have done fire training .... another 2 minutes and I would have been calling in the Big Red Trucks for assistance and kept battling with it..... Hope I got it all ... cant see any smoldering or smoke at all and I am checking every 5 minutes or so.
