mirrorcarp27
Hi it's been a long time since I have tried to get my Tarot 450Pro Super Combo FBL set up but not sure what I should use. At the first attempt I was using Tarot ZYX 3 AXIS GYRO with software via Laptop
but was having problems setting this up with this GYRO. Now I am using a kbar v2 5.3.4 pro k8 3 axis gyro flybarless system with software via Laptop. When I was using Tarot ZYX 3 AXIS GYRO I could flip the switch on my Spektrum DX6i called (P) Gear/Flight Mode this would show up in the software and on the unit with a LED light and would make the Rudder controls different like not going back to centre until new signal was given?. Now that I have change this to the Kbar when I do the same thing flipping the switch (P) Gear/Flight Mode it shows up in the software that I have flipped the switch but it doesn't do the same thing as before it always goes back to centre on the Rudder so I am not sure which one to use I have been watching loads of Video's and been reading the forum pages for info help as I am a new beginner to flying helicopters I got this kit about 2 years ago and it's still not been in the air yet. I also got my first Flight Simulator called ACCURC which has helped me with the flying experience but have crashed a few times and not costing me in repairs what setting should I use in my TX as a beginner when I do take this bird out for a maiden flight any help would be great at the moment I going to take the head off and check all my linkage are the same length and going to check the swash plate is level
