I am using a old erazor 450 motor in my clone, and I have to place a spacer to lower motor just enough to line up the pinion gears with the flywheel. I am tired of every time I spool it up the motor moves, or it strips the gears. I want to fix this one or put another in it. There is only a small area/notch in the shaft to slide the pinion up and down. Is this normal? Any suggestions.?
is there a shaft that has a bigger slot in it? For more adjustability of the pinion gear up or down? Can I remove the shaft of a motor? Or make this one shooter by sticking it in a vice?
