Morelight
Fearless Freep
It was finally nice enough today to take the heli out for first hover and tweaking. (BananaHobby - 6 CH 2.4GHz BlitzRCWorks Tornado V2 RTF Radio Remote Control Helicopter). I've carefully, I thought, checked out the bird, got blade tracking perfect, controls are mode 2, rudder worked fine once I installed a new rotor control arm, (it was broken when I got it).
She spools up great, and then at 50% stick, I expected her to lift off and begin my CP training. Nope. Even at full stick she stays put on the ground. Guess what I said then.
I bring the bird home and put her on the stand and spooled it up to realize the heli is pushing air up not down to lift. Pretty sure the blades are on properly. Reversed them anyways and same thing. Seriously, 4 feet in the air on the test stand and Zero downdraft.
This heli is supposed to be 100% flight tested. How did they get it off the ground to test it? The Tx is not a name brand, and I never changed any of the settings in it, or changed any wires etc. Its supposed to be RTF after all. I did see the throttle curve for normal and 3D and they were generic. I don't know enough about all the other settings to change or even know if they are wrong.
I've taken pictures of the bird, and of the manual for the Tx showing what are supposed to be the settings for the Tornado.
Man I just want to start flying other than sim flying, and I've already had a month of hell getting an RMA from BH for a smaller so called RTF FP120 that was returned, since it was completely unflyable out of the box and smacked a wall on first hover attempt.
This hobby is hard enough without being screwed over by companies that sell junk. Hope you all have heard of this before and know a fix for it.
Thanks in advance
Vince
Thanks in advance
Vince
