Keith
Well I'm off a running to give this Tricopter a go..
I got all the bits and pieces at HobbyKing except for the odd nuts and bolts and things I already had..
Here is most of the things I ordered.. Ordered two lots of props, 9x4.7 and 10x4.7 but forgot to show them...
From all the builds I have read about most say the hardest part is making a swivel joint for the rear motor. It controls the rudder or yaw. So I thought I would start with that..
I didn't find it that hard actually. First I got main the blade grips from a old 450 head I had. I then slid a piece of plastic tube from a water sprinkler system over the feathering shaft. Then with a couple of washers I was able to tighten the bolt in the other end to hold it all together. I gave it a good coating of five minute epoxy and slid it into the carbon tube. Even though it is square tube it has a round centre approx 8mm..
Now I had to mount the servo that would control the rudder. I cut two pieces of aluminum angle and pop-riveted them together. I then cut out two slots. One for the servo and the other two fit over the boom..
I fitted the servo to the mount and put them on the boom. I used epoxy to hold the mount firm. I then made up the linkage and fitted it to the motor mount swivel..
I got some flat strip aluminum and cut out the actual motor mount. I took the mount off the motor and had to drill out bigger holes for the nuts and bolts I had. I then mounted this to the aluminum mount..
I attached the motor mount to swivel assembly (blade grip) and re-fitted the motor.
I connected it up to a servo tester and it works a treat..
Here's a view from underneath..
So that's that part finished. I started on the platform next. I found some Plexiglas I had laying around and decided to use that. I thought the best way was to make two equilateral triangles and sandwich the tube between them. I made two smaller ones first so I could get the sixty degrees needed. I cut the shapes out and used a grinding wheel to get the angle correct. I kept rotating one on top of the other until all sides matched. I knew I had it spot on then. I just transferred the angles to make the larger base plates..
I then cut them out and finished them on a rotary sander. I aimed for around 200mm sides but near enough is good enough. As long as all sides are equal the angles will be right. Each boom must be 120 degrees to have it all balanced. So 60 degrees + 120 degrees = 180. Also you will be using the helicopter 120 programmed setting on your Tx..
I sticky taped the two pieces together and marked them out for drilling the bolt holes that will hold it all together. And thats as far as I've got. Not bad for one day. I'll be back at it tomorrow and will keep you updated as I go..
Leave comments and any questions and we will do our best to answer them.
