trainrider06
Hi Rodney, thanks for the feedback.
I'm planning to go to my workshop today and seriously test out the options for what I consider the best cable runs. I measured up the Axon and the base gives 12cm2 area to stick it down with and the two edges only half that, so it needs something extra to satisfy me that an end mounting is secure enough. Up to now, I've been thinking of installing it with no servo lead extensions but it's beginning to seem that won't be possible up front. Rear mounting is the only position I see works on that one but then the ESC and Rx. wires need extending instead.
I'm not under pressure to rush this as I've ordered up a clever box of tricks to programme the ESC. It also says in the downloaded ESC manual that one shouldn't power it up for the first time with anything other than fully charged flight batteries. If I hadn't read that, I would probably have been tempted to start working with my small battery just to give power to the gyro, so better that I haven't powered the heli up yet. The Axon can take its power supply from the USB to update firmware and register the unit with the software for use. Better than my Spirit Pro.
I'll keep you in touch with developments.
Myself I would much rather use extensions for the RX and ESC than all three servos just seems a little less extensive to me hehe...
Hi all, here are a couple more photos of another option that works without extending any of the leads from what I can see at the moment.
#001a View attachment 17016 #001b View attachment 17015
It's all temporary with nothing checked for accuracy as to which connection is plugged in where. The tail boom has a +5 degree angle from the ground so, of course, the gyro needs to be parallel with the boom and main rotor rather than the ground as it is in the photos.
Ah well done Phil! I like that mounting area also! I'm with Steve on the extensions especially with those bigger choppers and the what looks like 220 volt cables used for the servo's and such!
That looks like a pretty good option Phil. I managed to install the Vbar in the forward position without any extension leads but the end orientated connections helped.
Today's good news.. i think I've sorted out the spare parts for my repairs. I've found someone selling a new unflown 700X airframe + blades and motor for a decent price. It's more than the spares would cost me but I dont have to wait for stock and it gives me a whole spare airframe plus I can perhaps sell some of the bits that i dont need (like the motor etc.) I'm keeping my fingers crossed until i see it firsthand but in the photos it all looks as new.
Hope that works out Steve nothing more sucky than waiting on parts!
