sneezy007
Hey guys,
Been watching lots of videos on soldering. I need to solder 5.5mm bullets to a Castle ESC.
The ESC has 10 gauge wire which is pretty thick. I gave it a go yesterday but because the wire is so thick I couldn't get the solder to flow into the wire to tin it. I ended up putting solder on the iron and kind of spreading it around. The soldering iron I am using was set at 750 degrees but the ESC wire was getting pretty warm so I started getting worried. Most of the videos I've seen for these bullet connectors are the cup design. These ones are from HK and they have an open half cup design. I couldn't find any videos for this type of connector.
Anyhow these are the pictures of my work. Does this look ok?
Thanks,
Dino
Thanks,
Dino
