callsign4223
Since Tony is showing off his new saltwater setup I thought I would show off mine too.
This is a 55 gallon, semi planted (1 real plant at the moment), freshwater tank. It currently houses 1 longear sunfish, 1 green sunfish, and the newcomer 1 smallish pleco. I was trying to keep it a native tank, however there aren't a lot of native algae eaters that can stand up to the sunfish I have in it. I used to have about 2 dozen lake caught minnows in it, they lasted about a week until the first time I forgot to feed the sunfish, then they became food.
I am thinking about trying to grab some large minnows from a bait shop to get some schooling fish to finish the tank off. I will also be adding some more native plants to replace the plastic ones.
Here is an overall shot of the tank, the longear is the big one in the front, you can barely see the green on the bottom right side and the pleco on the top left.
Feeding Time!!!!!!!!!!
Here is the Green
Here is a closeup of the Longear from the front
Here is a closeup of the Longear from the side,
Here is the Plecos belly
Here is the Green
