  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
General Mounting A Camera
Discussion in 'Airplanes' started by BCJ, Jan 16, 2020.
< Instant Gratification | Low-wing Vs High-wing Piloting >
  1. BCJ
    BCJ New Member
    Jul 1, 2017
    16
    0
    1
    Gender:
    Male
    New York
    I got the RunCam 2 for Christmas and am thinking about how and where to mount it on my high-wing planes. I've surfed the internet regarding this but hope to get the benefit of your experience.
    Location: prefer not to be looking through the prop; concerned about the extra weight (49 grams / 1.7 oz.) affecting CG and balance
    Mounting method: is velcro good enough? Use the bracket that's included with the cam or mount the cam directly?
    Thanks.
  2. Tony
    Feb 21, 2011
    37,065
    1,453
    113
    If this is a single motor plane, then looking through the prop is really the only option. With the weight of the camera, you do not want to side mount it.
    As for how to mount it, as rigidly as possible, which takes out velcro. You can try it, and if it is okay, great. But I suspect there is going to be some jello in your video.
    Best thing to do is get a rear motor plane that is made for FPV if you don't want to see the prop.
  3. Fly-n-Low
    Fly-n-Low Member
    Oct 27, 2019
    81
    2
    8
    Gender:
    Male
    NE Louisiana
    CG on a high wing should be close to the spar of the wing. High wing, that would be above the prop some what. ? On top of the wing...?
  4. Tony
    Feb 21, 2011
    37,065
    1,453
    113
    High wing would be the wing is on top of the fuse. Low wing is under the fuse, and a mid wing is right inside the fuse. Think of, high wing = Piper Cub. Low Wing = P51 Mustang and Mid Wing = Edge 540.
Share This Page
