  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Motors Motor Was Hot?
Discussion in 'Electronics' started by D.O.G., Jul 24, 2020.
< Esc Resets Itself | Emax Hawk Pnp W/ Spektrum Spm4650 Wiring >
  1. D.O.G.
    D.O.G. Well-Known Member Goblin 380 Supporter
    Jul 9, 2013
    3,394
    151
    73
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    Thursday morning, if you watched the video, I took my 550 out for the first time. She flew marvelous but I did notice the motor was hot after the first battery. She flew hotter then my Xnova motor that I have in my X3L. I'm not sure if the motor suppose to run the hot or my settings are not correct. My timing is @ 18 degrees. The battery and the esc wasn't hot at all...warm. Any ideas to cool her down or that's the way this heli fly's.
  2. Tony
    Feb 21, 2011
    37,195
    1,466
    113
    You can try lowering the timing which should lower the heat. Another thing to look at is if you are using a governor on it. Some gov settings can cause some heat build up. Kind of like putting too much "D" (PID) on a quad motor.
  3. D.O.G.
    Jul 9, 2013
    3,394
    151
    73
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    Hey there Tony. Thanks for the response :). Yes, I'm running the gov. store on the hobbywing 120a. I will try lowering the timing. I think default is 15 degrees...don't bank on it.
  4. Admiral
    Admiral Well-Known Member
    Mar 2, 2014
    2,210
    135
    73
    Gender:
    Male
    Occupation:
    Information Technology (Retired)
    Brisbane, Australia
  5. D.O.G.
    Jul 9, 2013
    3,394
    151
    73
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    Yes, my X3l has the xnova motor. The XLPower motor doesn't have the timing setting but it does have the same # as Xnova motor so once again I assume 18 degrees will work too. The Xnova motor 1200Kv and the Xl motor is 1100Kv. So I will go lower the timing and see.
Share This Page
