mooserider
I originally had a question about batteries, but it evolved into a list of things I've always wondered about.
(flight batteries?) I often see helis or planes with more than one battery. Does that lengthen the flight time, or just speed up the motor? I learned at the los today that the mA rating is run time. I thought it was something that had to match the motor. Then he said it was based on the esc (mine is a bec and esc in one, 45a). My heli has no 'bec', just and esc. All this electrics stuff is so gd frustrating!
(nitro vs electric receiver?) To top it off, I bought a 4ch receiver (spektrum ar400) today for another airplane I am setting up (nitro 4ch). There's no battery slot (like, for a nitro plane bat). I read the instructions, which said to use the bind plug in batt/data, and the flight battery in any other slot. This seems to work, it seems to bind, but as soon as you re-power the receiver, it's bind is lost. Is it because this receiver is intended for electric use only? I read another article that said that you should always use 6ch receivers for nitro planes (which doesn't make any sense to me).
(satellite receivers?) While I'm at it (this turned into a rant, sorry), airplanes have no satalites, and helis do? Why? Or is it size, like on a 1.20 plane, you would want a satelite.
(fuel nitro %?) I think this is pretty much answered, but 10% vs 15 or 20 for nitro engines? Let's says I have these engines: OS 20, OS 46fx asb, OS 61 fx, YS110 (4-stroke). Can I just use 15% on all of them? Forget about tunning the engine if you change blends, I understand that. And I hear it makes the engine run cooler if you have a higher nitro content. Mainly, can I stick to 15% for all my engines?
(nitro breakin) Do you really need to run a nitro rich for the first few tanks before leaning it out?
Super bonus question: Why is it that nitro heli motors have square heads, compared to planes? Heat disipation or some such
