FBL Gyro Mini Vbar Hobbywing Rpm Sensor
scrc511
Hello folks, can someone pls show me or show me if you have a better way wiring the Hobbywing rpm sensor using this additional cable power supply/Phase sensor for mini Vbar? I've already wired mine but just to compare so if mine is wrong then I can make coorection. I'm gonna try and load the picture of the wire so if someone has the same wire maybe then you can share how yours is done. And by the way I'm using Futaba Sbus, wired to RXC into the Vbar, Esc on channel 3 of the Futaba Rx..
I have no idea how these are wired up, but I"m sure someone on here does. Bumping this back up to the top. Someone help this guy out please.
