callsign4223
My MCPx has been acting a little sluggish lately. It just seems to bog a lot easier than it used to. Also, it will hit the low voltage cutoff randomly after about a minute sometimes. The battery connector did pop off the wires, so I bought some replacement connectors and some extra wire to fix it. The new wires are A)Solid instead of stranded and B) A few inches longer than the old ones. Could this be the reason it is acting like this, or is there some other problem in here? My soldering skills aren't great, but the connections all felt really solid.
For an example, I am running 300 Mah batteries in it, and even running for 3 minutes I am only putting 150 mah of juice into them. One time when I hit the low voltage cutoff I actually swapped batteries thinking I might have gotten a drained one mixed up in my charged ones, when I charged it I only put 92 ma in it after about 1.5 minutes of flying.
