  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Other Lemon Rx Satellite Pinout
Discussion in 'Transmitters & Receivers' started by bigone5500, Jan 13, 2018.
< Ar7700 Questions | Dx12i. Thoughts?? >
  1. bigone5500
    bigone5500 Well-Known Member
    Blog Posts:
    0
    Mar 22, 2017
    2,042
    66
    58
    Louisiana
    I want to verify the pinout of this DSMX satellite from Lemon Rx. When looking at it from the top and the connector is on the bottom, the pinout is, from left to right, 3.3v, gnd., signal. Correct???
  2. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,505
    1,391
    113
  3. bigone5500
    Blog Posts:
    0
    Mar 22, 2017
    2,042
    66
    58
    Louisiana
    That one says diversity antenna. What's the difference? Mine just says DSMX compatible satellite. And the antenna wires are not nearly that long on mine.
  4. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,505
    1,391
    113
    Should be the same. All spektrum compatible satellites have the same pinout. Just pay attention to that 3.3 and don't put 5v to it.
  5. Smoggie
    Smoggie Well-Known Member
    Blog Posts:
    0
    Dec 14, 2015
    2,319
    122
    73
    Aberdeen, UK
    Diversity sats have two independent antenna and the sat selects whichever one is receiving the strongest signal. A standard sat has only a single antenna, the two 'whiskers' you see on a standard sat are just two ends of a single dipole antenna.
    The wiring is the same on both but it's rarelky an issue because the plugs are handed so they can only be connected one way.
Share This Page
