Chargery S1500 Power Supply PS-CS1500
EZ-Solder 4mm Banana Plugs
Connector Type Male XT90 Connectors
Universal Modular Charge Board
Banana Plug Binding Post for PRC Cases
Heavy Duty AC Adapter for PRC Cases
As for the other stuff I am holding out till later on tomorrow for the case, I chose the Seahorse SE720. I have a small laundry list of stuff at amazon also. I am thinking of ordering that stuff this week also. I hope to have everything here around the same time. My PRC order is backordered till the 13th of this month. Next friday is payday so if I order the odds and ends from amazon then Ill pay it off on friday. I will still be running my PL6 as the charger and I will be modifying the plug on it to accommodate the new power supply. My goal is the fewest connections possible to get it running. I just may end up with a generator before I leave but not sure yet, not a necessity at this point. I am so thinking about that bump charger right now. again will see.
This is going to be my last project for a very long time. So I need to do it right.
so just ordered the amazon stuff and it should be here around the 11th. I also ordered the bump charger which means I dont have to fuss around with the main charger. All I need to see is how the PC link is going to connect. Whats left? the case., a few banna plugs, some wire and cable ring ends.
