Ken Jackson
Ken ... are you sure you have enough Gain? sounds like your helis is doing the normal thing it does in Rate mode .... weather cocking down the the direction of heli attitude or the wind!
what gain settings are you set at? .... Spektrum radio ??
you should be setting it up so it wags its tail ... then landing and backing off 3 - 5 points until it stops.
Westy I have tried gains from 40 to 90. Yes Spektrum DX8. Did all the things you had suggested with the tail it is not binding. Brand new DS425M. Gyro is a GZp790. You can see in the video the gyro switch from rate to hold.
450 crazy tail - YouTube
Gyro at 70
450 Crazy tail 2 - YouTube
Gyro at 55
450 Crazy tail 3 - YouTube
450 Crazy tail 4 - YouTube
Since video I replaced main shaft and switched to a GP750. Also changing out the swash plate. We will see what happens next.
Ken
Mentioned this in another post. I don't think it should matter but you tell me. The tail is a Tarot TT conversion. It is for a 450 Pro and this bird is an SE. The tail boom is approx. an inch longer then the stock tail.
