I agree with what is posted above. If your gain is too low, your tail will drift and not correct. You will have to keep giving it stick input to bring the tail back around. Most times it will rotate the heli body CW when looking at it from the top. But, if your slider is not centered, it could go CCW. You want to adjust your gain until you get a wag, then back it down 5% and leave it. Make sure you are testing this in IU2 if you have it. Otherwise, 100% throttle to get the most accurate tail gain.
Also, if you are running a DX8, you have to go into the gyro menu and set the switch to gear, AND the channel to gear for the gain to work. If you are doing this on a 3GX with the DX8, then Gear is your Gov and your gyro is on channel Aux2. Confusing I know, but it is what it is. Hope you get it figured out soon.
