Hello! First of I'd like to say that I loved this site! Been reading up and down on things here!
Been checking youtube links, reading different web pages but am stuck!
I purchased the Blade 450 3D RTF incl. the DX6i, and also the Phoenix rc4 sim to learn to fly helis
My first thing was that when I started the sim, choosed the 450 3D heli, and it constantly went sideway and crashed!
Went through the books, and tried to setup the tx to beginners ( intermediate ). After fiddling around in the settings a bit, I made it so pushing the throttle from 0 and up made my heli start spinning, and I could half way fly it a bit!
THEN ... in my moronic way .. I just HAD to try out some things, and managed to delete both the 9th and 10 setup on my tx.
Now nothing works. I tried to set it up again following the setup guide in the book that followed the 450 3D, but again .. in the sim it goes sideway and crash. Whenever I touch the throttle stick, it moves both sticks in the sim, crashing the heli.
I have no idea how to fix this!
I have setup the tx to fly the Blade MQX, and it flly nicely ... fiddling abit with the D/R Expo to adjust the normal to make it fly better ( I've gotten used to the org. tc for the MQX ). STUNT is at max, and I more use this than normal atm.
But I do want to learn to fly my 450 3D without crashing within 10 seconds
Here is what I am looking for:
I want to use the thhold/mx to start/stop the engine from spinning the blades.
throttle start from 0 to full will make it fly ( not 3d flying or positive/negative pitch ) so I can learn to use the throttle to make it fly up, and slowly learn to fly up and hover...fly side to side .. and like that!
The advanced stuff is for much much later for me ( yes I know .. I'm an old git )
Could anyone advice me on what settings to use, how to set it up and so on? I don't understand ie. what swashtype it is .. I've starting to understand what these things mean from watching youtube and such! Not sure what to change with D/R, travel adj, sub trim, gyro and all these others...
I have setup the settings from the instruction sheet ... but I just can't get it to work! Think I need a beginner/child mode to start with!
I hope I've been able to explain my problem, and what I am in dire need of help with, as English is not my native language, I might use wrong words/spelling and/orr not being able to explain the technical words/terms for this. I do apologize for this in advance!
Thank you so much in advance for any help I can get!
Shaddiz!
Arild Halvorsen
Gear:
Blade MQX
Blade 450 3D
Spectrum DX6i
Phoenix rc4 SIM
edit:
When I said I managed to delete 9th and 10th setup, I meant I managed to delete the org. factory setup model advanced and intermediate for the 450 3D. Ended up with a clean, empty tx.
It's after this I made models/profiles following the instructions, making an new advanced and intermediate profiles, plus the mqx profile ( and the mqx one is the only one working )
Shaddiz!
Arild Halvorsen
Gear:
Blade MQX
Blade 450 3D
Spectrum DX6i
Phoenix rc4 SIM
edit:
