General Just a small tip
Karubah
I don,t know if anyone else has had trouble trying to start feeding plastic linkages onto linkage rods. I found it easier to put a small champher on the end of the rods and it is a lot easier to screw on. I used a very small jewellers file and put 45 deg. Bevel on the tip of the rod. Cheers Andy
Great tip. I hold the rod with a pair of pliers then push as I'm turning the end. Has worked for me.
I have used a drill bit. I only open it just enough for the rod to bite into the plastic. Trust me its not a lot. I spent hours on trying to build linkage rods.
