This thing has a massive setup learning curve. At least for me anyways. I just got it put somewhat on the EXI and have the wires ran down the inside of the frame. I discovered the wires are a bit short to run out the back, so I have to run them out a side hole, not to keen on that but thats all I have to work with.
I have a dumb question since I should already know this answer, I got 2 pieces of white sticky foam tape, the pieces are thin; So do I bite the bullet and use both or do I take a chance and use one?
Specs given By JR
Operating Volts: 4.8 to 6.0V (Common Receiver)
Operating Current: 55mA
Size(mm): 8.8(H)x23.4(W)x23.4(L)
Weight: 7g
Gyro Gain: Remotely Adjusted
Tail Lock: Interlocked with gyro gain
Others: Reverse Switch, Zero or low Deadband Switch, Servo Travel, Auto Trim
Just to give you a brief taste
TX settings:
Rudder travel Adjustment Right 120%
Rudder travel Adjustment Left 120%
Sub trim 0
Trim Center
Revo mix 0%
Tail Lock Off
What is deadband?
zero deadband the gyro will be more reactive to small disturbances
low deadband the gyro will be less reactive to small disturbances
Specs given By JR
Weight: 7g
TX settings:
Sub trim 0
Trim Center
Revo mix 0%
Tail Lock Off
What is deadband?
