Mda1701d
Hello all,
After spending all weekend going right through all the setup again on the 450L, and replacing yet another stripped tail drive gear set, all is still not well.
I went right through the DIR again, swash is now dead level high, low and mid. All blade pitches checked and CG perfect.
Spooled up again tonight to check, and still the heli wants to tip when on the ground, if left for more than about 10 seconds. So I tried to pop it up a bit sooner, with throttle lowered to about 40%, but the heli is instantly unstable and cant be corrected in time before yet another tail strike, and more stripped gears.
I wonder if its the training gear upsetting the gyro (3GX ver 4) and causing more problems than it is helping.
Does anyone else have a veiw on this, or any more ideas?? I know many people say that training gear cant be used on these, I would worry that it will go over the minute I spool without now. Im going to order one more set of gears, then give up I think.
Thanks for any help,
Mark
Mark
