Spektrum Info on dx8
Kronchy
My stunt mode broke..can i assign a diff swith..need to see how the trex250.does with idle up????? Thx. Fyi if i cant find a way i will buy another dx8
What do you mean your stunt mode broke? If just the switch broke, you can go to an electronics store and just get another one. It's a simple 3 wire switch with a nut. No need to buy another one.
And as far as I can remember, you can program to another switch, but I highly suggest against doing that. Always leave your idle up switch and your hold switch in the same locations at all times. That way if something happens, you don't reach for the wrong switch.
Kronchy
Year remote fell n it snapped off n went to mode 1 so i tinkered with the wires n switch back to mode two...so i cant buy a switch..i can do with out it..ohh got the trex up in the air now i got to wait for snow to melt...
Or its the idle up switch
I'm not sure why you can't buy a switch. It's $2 compared to a couple hundred. Even if it cracked the case, you can still epoxy the pieces back on, or even CA them.
