  2. Hey Guest, are you here looking for the PDF Plans? They are located in the store in the tab above, but you must be signed in to access that part of the site. It only takes a second to sign up!
VTX ImmersionRC 5.8ghz 600mw troubles
Discussion in 'FPV (First Person View)' started by Derek, Aug 27, 2017.
  1. Derek
    Derek RC Help Supporter
    Blog Posts:
    0
    Aug 3, 2012
    5,724
    241
    63
    Fort Wayne, Indiana, USA
    I'm having troubles getting this setup to work on my wing. I have a JST plug, from the Battery In, to the vtx and to the camera. The camera requires 12v in. So, once I plug in the battery, it should power the FPV cam, vtx, and esc/rx/servos. However, this isn't the case. I plug the battery in and I see the vtx light come on and the motor and servos all work. But, I get snow in my goggles.
    I am very sure that the goggles on the same frequency and channel. This is verified by powering up my other FPV plane and checking.....I get strong video.
    Attached is an illustration on how I have this wired up
  2. Derek
    Blog Posts:
    0
    Aug 3, 2012
    5,724
    241
    63
    Nevermind...after retesting all the wiring, camera, and another vtx, all my retesting showed that the only thing that could be the problem points to the vtx, itself. I inspected it seriously carefully and I found that the SMA connector had been resoldered, poorly, to the vtx and the SMA connector was loose. Loose enough, in fact, that I was able to pull the SMA connector clear off the vtx. This is what I get for trying to save a few bucks and buying a second hand item. I should have just paid for a brand new one. That's what I'm going to do after I finish this post.
  3. Tony
    Blog Posts:
    10
    Feb 21, 2011
    31,863
    1,205
    113
    Did that thing rip the traces off the board? If so, that VTX has been in a hard crash. I have had the same kind of luck to be honest. If you have a small enough soldering iron, you should be able to repair that connector. Might have to strip some coating off the traces that are left though, and epoxy the SMA back to the board, unless the traces are still there that is.
  4. Derek
    Blog Posts:
    0
    Aug 3, 2012
    5,724
    241
    63
    Nope...the traces are gone.
    No matter....i put the vtx in the trash and accepted the loss.
    Im gonna order brand new Cricket vtx next week. I think i remember Tasajara using these with success
Share This Page
