FBL Gyro Ikon2 servo/battery/esc ports
So tonight i stsrted switching over from the 3GX to the Ikon2. Im confused on what channels/servos go where, except for the servos. Pretty sure that was easy.
If anybody could post a diagram on where the rest go that would be great
What type of receiver are you using? Are you using a full receiver or are you using satellites?
Maybe this will help. There should be a similar image in the Ikon set up
Its setup with two spektrum sats and the receiver is the ikon 2
Running of of my casrle bec are 2 red wires and two black wires totaling 2 plugs. Each plug has a black and red lead going to them
I have that same BEC on my Trex 600 with Ikon. I'd like to ask, again, what receiver are you using? Are you using a full sized receiver or are you using satellite receivers? I'm asking this because if you are using a full sized receiver, then the BEC will plug into the BATT/BIND port on your receiver. If you are using satellite receiver(s), the two leads will plug into channel 2 and channel 3. It's not necessary to have both leads from the BEC plugged into the Ikon but it does give a bit of redundancy protection. I have both leads plugged in on my Ikon.
Check out this image -
Now, this is how I have mine set up. Double check your voltage specs and set your BEC to the voltage that your servos can handle, i.e. 6.0 or 7.4. Disregard the Y harness part of this image, as I imagine you won't have a fan on yours.
do you mean DSM2 sats? If so, then your setup is similar to mine. I have two DSMX sats on mine. If that's the case, just follow the diagram in post number 5 and connect your BEC Pro to CH2 and CH3 on your Ikon.
Yes, that's what I have. Sorry, i usually type from a tablet.
The previous owner flew it with the 3GX and this controller. He said he ran the default and never messed with setting up the BEC so i bet its kicking out 5.1 volts. Ill check today. iF that is the case and my servos can handle more, what is the advantage, im assuming quicker response....what if i leave it?
5.95volts coming off of the BEC.
Align DS510 on the Aileron, Elevator, and Pitch
Align DS510 - Digital Mini Servo
Specifications
Modulation: Digital
Torque: 4.8V: 51.38 oz-in (3.70 kg-cm)
6.0V: 63.88 oz-in (4.60 kg-cm)
Speed: 4.8V: 0.13 sec/60°
6.0V: 0.11 sec/60°
DS520 on the Rudder
Align DS520 - Digital Mini Servo
Specifications
Modulation: Digital
Torque: 4.8V: 26.40 oz-in (1.90 kg-cm)
6.0V: 34.70 oz-in (2.50 kg-cm)
Speed: 4.8V: 0.09 sec/60°
6.0V: 0.07 sec/60°
According to the specs, and correct me if I'm wrong, if the BEC is kicking out 5.95volts and these are rated for 6volts, I should be okay right?
